The Viewer role gives you a simple and secure way to control who can see your published projects.
This guide explains how the Viewer role works, when to use it, and how to apply workspace restrictions to keep your content private.
What is the Viewer role?
The Viewer role is a Premium feature in Cadasio that allows users to view published projects without any editing permissions.
Viewers cannot modify projects, layouts, or assets. They can only log in and access the projects they are authorised to see. This makes the role ideal for colleagues who need access to instructions or presentations but should not make changes.
Common examples include:
  • Shop floor staff
  • Assembly line workers
  • Training participants
  • Internal stakeholders reviewing content
How Viewer access works
When a user with the Viewer role logs into the dashboard, they see a list of published projects they are permitted to access. This ensures they only see relevant content and nothing more.
Because access requires login, your projects are not publicly available to anyone with a link.
Managing access per project
Viewer permissions can be controlled on a per-project basis.
This allows you to:
  • Share some projects publicly
  • Restrict others to internal viewers only
  • Adjust access depending on the sensitivity of the content
This flexibility is useful when some materials are customer-facing while others are internal.
Applying workspace-wide restrictions
If you want all projects to stay internal by default, you can enable a global restriction.
To do this:
  1. Go to Workspace
  2. Open Security
  3. Enable Restrict to Workspace
This setting:
  • Applies to all existing projects
  • Becomes the default for new projects
  • Can still be overridden for specific projects if needed
Ideal use cases
Using the Viewer role and workspace restrictions is especially helpful for:
  • Internal training materials
  • Assembly instructions for production teams
  • Confidential documentation
  • Review processes before public release
In each case, you maintain full control over who can access your work.
Secure sharing made simple
The Viewer role provides a practical balance between accessibility and security. Your team gets the information they need, while your projects remain protected from unwanted access or edits.
By using per-project controls or workspace-wide restrictions, you can confidently share Cadasio content internally while keeping sensitive material private.
